May 15, 2017 1:47 PM UTC
Sequencing in HoloLens
Is there a way to import a sequence along with a .pvz into Studio for use with HoloLens because the 2D widget functionality does not seem to be present in Studio when Eyewear is the Project type? Sequencing works just fine in normal AR project mode (importing the .pvi as a Resource, etc.) If this is possible, how do you get to play a sequence if 2D widgets are not enabled?
Many thanks as always,
Brian
katteAnswer
May 15, 2017 2:02 PM UTC
Brian,
Playing a sequence is quite similar to normal AR project mode. In Eyewear project, we can bind the application event to play the sequence. For example, I was using 'Double tap' event to bind with 'Play all' service of the 3D model.
-Giri
katte5-Regular MemberAnswer
Brian,
-Giri
May 23, 2018 11:38 AM UTC
Hi Giri,
true, but sequences has ALOT of problems. Hololens aren't playing 90% of sequences..right? 🙂
Bojan
bwhelan1-VisitorAuthor
May 15, 2017 2:05 PM UTC
Giri,
As always many thanks for answering so promptly!
Great stuff!!
Brian
