Jun 7, 2017 2:36 PM UTC
Show a PDF file in Thingworx Studio
Hi everyone,
I'm trying to show a PDF file in my thingworx studio experience, but i did not see any widget to do this.
I tried to import a PDF file in resources folder, create a $ionicPopup in the javascript file and in the ​template​ section i wrote HTML code to show PDF file, like this:
$scope.popup = function() {
    var options = {
      cssClass: 'popup-custom',
      title: "PDF!",
      template: "<iframe src='app/resources/Uploaded/prova.pdf' frameborder='0' style='width: 100%; height: 600px'></iframe>",
      okText: "Close"
    var popup = $ionicPopup.alert(options);
    popup.then(function(res) {
      //do something
​In ​preview​ mode I see my PDF file correctly, but if I use a mobile device (with the Thingworx View app), I don't see my PDF, only white area.. I think I need to import something.. I tried to import the PDF.js library, but it did not work..
Anyone can help me?
Alessio
Message was edited by: Sushant Pandey moved to ThingWorx Studio
Jun 19, 2018 8:55 AM UTC
Hi, I was able to view my pdf file, however my pop up window width is very small. Please help on how to change the size of the popup window..
I tried to change the value of the width in my js and css but the pop up window width remains small. (not changing at all)
below is my js:
$scope.show = function() {
var alertPopup = $ionicPopup.alert
title: "Flexure Assembly!",
template: "<iframe src='app/resources/Uploaded/Flexure Assembly.pdf' frameborder='0' style='width: 100%; height: 500px'></iframe>",
okText: "Close",
Pls help.. thank you!
