Show Fluid Flow Passages
- 6 replies
- 5468 views
- Translate All
This is a bit of a challenge. I think there may be a variety of creative solutions:
I would like to show in AR the passages where oil-flows within a special pump. I have attached an image of this. In Creo Parametric I am able to turn down the transparency of all parts to about 80% and then color the surfaces where oil flows. You can see they are bright red with no transparency. So you can see through the transparent pump and understand the passages inside.
However when I export this as a PVZ, the red surface coloring disappears. I would love to somehow select all the surfaces and turn them into a quilt or a solid geometry that I can then add back to the model. As it is now, they are just a void space within and between various parts of a complex assembly.
Even better would be the ability to show dots, arrows, balls, or some representation of fluid flow through the passages. This sounds very labor intensive if I did this all manually.
The end goal is for the technician to be able to walk around the AR pump and see the void spaces inside where the oil flows. Also - a related side note - has anyone figured out a hack to show X-sections in AR? This is another way that internal components with passages could be explored & understood.
Thanks for your creative ideas!
Wes
