Nov 11, 2021 5:08 PM UTC
Show/Hide separate models on 3D button clicks for Hololens
I'm looking to be able to show a particular model and hide all others on the click of a particular 3D button.
On scene entry, I want a particular model (Model-1) to show and all others to be hidden, which I have done with the following code:
$scope.Test = function() {
  $scope.setWidgetProp('model-2', 'ForceHide', 'true');
 $scope.Test();
  $scope.setWidgetProp('model-3', 'ForceHide', 'true');
 $scope.Test();
  $scope.setWidgetProp('model-4', 'ForceHide', 'true');
But then I want to SHOW each model separately when a particular button is pushed.  Then if a user
Nov 12, 2021 11:04 AM UTC
you just need a function like this:
$scope.UpdateVisibility = function(widget, visibility) {
    $scope.view.wdg[widget].visible = visibility;
Then enter in the JS box of the click event for button 1:
UpdateVisibility("model-1", true);
UpdateVisibility("model-2", false);
UpdateVisibility("model-3", false);
UpdateVisibility("model-4", false);
For button 2:
UpdateVisibility("model-1", false);
UpdateVisibility("model-2", true);
and so on.
