Feb 17, 2021 11:16 AM UTC
Spacial target on android 10
I have create a project with a spacial target. But when I am opening it with my phone (android 10) on vuforia view, it notifiying the device don't support spacial target. When I try with IOS device, it's work.
I think it worked with my device before the last vuforia update;
Do you know if any updates are planned to make it work again?
Thanks,Maxime.
Feb 17, 2021 10:19 PM UTC
Hi @MaximeDid ,
could you, please, specify exactly the mobile device (e.g. Samsung Galaxy 9+ etc...) and system info
In Android > settings > Telefon Info  - model number and > Software Information  :: eg. Android Version 10 Basis Band version a, Kernel Version and Buildnumber (also?or. picture , snapshot) etc.
- What is the Vuforia View Version? Is already the current 9.0.1.2567?
- Also a good point to check the issue  could be the Vuforia View log file. So if you test the problem  and are able to reproduce the issue and then extract the log file : according to https://www.ptc.com/en/support/article/CS283816
Where to find Vuforia View logs
Description
Where to find Vuforia View log files on various devices
What is the Location of Vuforia View logs / debugging logfiles for IOS, Android, HoloLens and Windows devices
Resolution
iOS
Connect your device to a computer with iTunes on it
In iTunes, select the device
Select File Sharing in left side menu
Select View in list of apps
Drag logfile.txt to desktop
Android
Log files are located under Android folder
..\Documents\Vuforia View\
logfile.txt is the most recent log
Windows Surface
Log files are located at C:\Users\{userName}\AppData\Local\Packages\9CAFC431.VuforiaViewEnterprise_fvvfpfxfdh1zr\LocalState\
File is named log<date>.text
HoloLens
Open a web browser
Navigate to device portal by entering the IP address of HoloLens
Select File Explorer > Camera Roll from left side menu
Download latest log file
Vuforia View must be closed to download log file
So I have my self also mobile device with Android 10 - Samsung Galaxy 9+ and so far I check it - it seems to work  for a targets, but I believe also that the detecting the surface is some time not working when there is no good environment light. On IOS it works better, so my impression
Actually  when the devices supports the  Google ARCore according to the list below it should work:
https://developers.google.com/ar/discover/supported-devices?hl=en
MaximeDid1-VisitorAuthor
Mar 5, 2021 7:03 AM UTC
 Hello @RolandRaytchev ,
Thanks for your response and sorry for the late feedback...
Here is the required information:
Mobile device: Redmi Note 7
Android version: 10 QKQ1.190910.002
Vuforia view version: 9.0.1.2567
In attachment, you'll find the log file.I tried to read it but I don't know what information to look for.
In fact, as soon as I open the project containing a spatial target, a message appears notifiying me that this function is not supported by my phone.
Thanks for your help.
