Aug 22, 2018 10:52 AM UTC
Spatial Target Image does not zoom/scale
I am using a spatial target for the experience. Now, When I zoom the model, only the model zooms but the 3D images placed around the same are not zooming.
Let me know if there is anything can be done to address this.
Avinash
Aug 22, 2018 3:23 PM UTC
What do you mean by zoom? Pinch to zoom in spatial, or do you have a slider scaling the model?
agangaiah5-Regular MemberAuthor
Aug 23, 2018 5:57 AM UTC
By Zoom, I meant that whenever I take the mobile device closer to the experience, it starts to flicker.
Is this a known issue?
Avinash
Aug 23, 2018 12:32 PM UTC
Flickering sounds like you are loosing tracking. I would try a different environment, maybe more light, or outside. You could also try a different device. Even as an Android devote i have to admit that newer Apple products seem the track the best.
Aug 24, 2018 1:23 AM UTC
What file format are the images?  I've seen this happen where a JPG image won't scale, but if I convert it to a PNG, then I can scale using the gestures.
Cheers,
Allan
Aug 24, 2018 5:48 AM UTC
Hello Allan,
I am using png format only but still not able to scale with gestures.
Avinash
