Jamal Ashraf
Jun 29, 2026 6:53 AM UTC
SSO Logout Issue in View App – Credentials Persist and Prevent New User Login
Hello everyone,
I am currently facing an issue with Single Sign-On (SSO) in the Vuforia View app (iPad) and would appreciate any guidance or best practices.
Scenario
  • I log into the Vuforia View app using SSO (Microsoft Entra ID).
  • The login works as expected.
  • However, the app persists the session/credentials internally.
Problem
  • I have implemented a logout flow from Microsoft Entra ID.
  • When clicking logout, the Microsoft logout window appears successfully.
  • However, after logout:
    • The Vuforia View app automatically logs the same user back in
    • It appears that the app still uses stored cookies/session data
Impact
  • A different user cannot log in after logout
  • The only way to allow a new user login is:
    • Manually going to Settings → Remove Credentials & Cookies
  • Only after that, the login screen (SSO window) appears again
Requirement
I want to achieve the following behavior:
  • After logout, the next user should be able to log in via SSO
  • No credentials/session should persist at the app level
  • Ideally, this should happen programmatically or automatically, without manual intervention
  • Is there a way to clear cookies/session programmatically in Vuforia View?
  • Or is there a recommended approach to force fresh SSO login every time?
  • Has anyone implemented a solution for multi-user / shared device scenarios?
Any suggestions, workarounds, or architecture recommendations would be highly appreciated.
Thanks in advance!
