Jun 29, 2020 8:46 AM UTC
Stop the Speech
I am using the below code to convert text to speech for my AR experience.
$scope.speak = function(){
var spokenText = $scope.view.wdg["label-1"].text;
var msg = new SpeechSynthesisUtterance(spokenText);
window.speechSynthesis.speak(msg);
Help I need:  I need to be able to stop the speech in middle(in case the speech/text is too long) and move to the next step.
Any thoughts on how this can be achieved?
Avinash
Jun 29, 2020 5:17 PM UTC
Hi @agangaiah ,
as we discuss this outside the community , you informed me that you already found the solution. Only for the sake of the completeness I will post your solution here:
//Below method works..
//you can add a button say STOP....call this function stopallaudio()...code as below
$scope.stopallaudio = function(){
window.speechSynthesis.cancel();
Hi @agangaiah ,
agangaiah5-Regular MemberAuthor
Jun 29, 2020 5:19 PM UTC
Yes worked. Thanks
