Apr 16, 2019 12:47 PM UTC
.stp model appearing as a cylinder
Hi all,
I am trying to use a STEP file ("name.stp") in a Vuforia Studio project. I am using Vuforia Studio version 8.4.0.4300 and the file is a part of a machine.
The problem comes when I add a Model in my canvas and I try to add this resource: it appears as a simple cylinder.
I would be very grateful if somebody could help me to solve this problem.
Thank you very much for your time!
Apr 17, 2019 1:09 PM UTC
Hi @Andrea_sbsst ,
I think there could be 2 things the problem.
- some problem in the step files, some errors or incompatibility or
-the model size - to large
So I will try to import the step model to Creo Illustrate if this tool could display the step assembly  and publish it to pvz.
So this will create a new pvz file. Is this file visible in the Creo view - if yes this should be also visible in studio- (I hope)
Apr 16, 2019 5:26 PM UTC
Hi @Andrea_sbsst,
Are you able to share the step file so that we can take a look? If not, can you share a screenshot of the model in Studio as well as what it's supposed to look like? Are you getting any errors when importing the file?
Apr 17, 2019 7:46 AM UTC
Thank you very much for your answer!
I am afraid I can't share the stp file, but I attach an image of how it looks now in studio:
The stp file looks similar to the following image:
On the other side, I am not getting any errors when I import the file.
Am I maybe seeing just a piece? Is any constraint in capacity?
Hi @Andrea_sbsst ,
