May 8, 2018 5:30 AM UTC
Studio Time Series charts - styles?
I'm using a Time Series chart to monitor some real time data, and would like to turn off the re-scaling effect that occurs each time the refresh is triggered. I have a fixed/known range of data I'll be monitoring. Is there a css style for this? I note that in Thingworx Composer the Time Series chart has a lot more options/controls than in Studio, and perhaps something like AllowYAxisZoom or YAxisAutoscale are the ones I need to play with, but there is no UI for this in Studio...)
Thanks in advance...
dupatelAnswer
May 29, 2018 6:47 AM UTC
@GregBrown: Unfortunately, we do not have a CSS reference for all widgets.  The charts in particular are limited because they use other tech to render.
The widgets are mostly themed in a similar way, and much inherits from the Ionic light theme.  The DEV tools are the best way to see whats up with the widgets.
-Durgesh
May 9, 2018 12:32 PM UTC
@GregBrown I agree at present the Studio Time series chart widget do not offer additional properties & controls similar to that available on ThingWorx . I  will check on the CSS style and get back with more details.
-Durgesh
GregBrown5-Regular MemberAuthor
May 10, 2018 12:11 AM UTC
Durgesh,
Thanks! I'll be very interested. Actually there's a wider question about CSS with other widgets. I've worked out a few, but it seems like there should be a more accessible list somewhere?
Cheers,
Greg
dupatel5-Regular MemberAnswer
-Durgesh
