Mar 19, 2018 6:14 AM UTC
Switching between Models Visibility Using Single Toggle Button
The scenario:
I have 2 models namely Model1 and Model2.
I want only model1 to be visible by default when the experience is loaded.
I have a toggle button, which when pressed, hides model1 and displays model2 and vice versa.
Issues I am facing:
Both model1 and Model2 are visible initially.
I have tried binding toggle button property "Force Hide" to model2 which successfully keeps it hidden when the experience is loaded but upon clicking the toggle button it doesn't get visible.
PatrickOllerton
Mar 19, 2018 7:39 AM UTC
hi,
It should work - does on my projects - so maybe something else is affecting the visibility? I would try to remove any code/bindings that affect visibility (like the Force Hide you mentioned)  and re-try.
If you still can't get it to work try in a new project:
1) Add a CAD model, set it to not be visible
2) Add a toggle button to your 2D view
3) Bind the button's "Pressed" property to the CAD model and select the Visible property.
That should be enough, good luck!
Patrick
PatrickOllerton
Mar 19, 2018 6:51 AM UTC
You can set Model2 to not be visible - access the Details for the model and de-select the "Visible" checkbox.
It will now not be visible when the experience loads and you should be able to toggle visible/not visible with a button.
Hope this helps,
Patrick
akanoo1-VisitorAuthor
Mar 19, 2018 7:24 AM UTC
Hello Patrick,
Thanks for the quick response.
As you asked, I unchecked the Model2 visibility property but it is still visible, both in preview and View app.
Maybe we need to override the settings by js code.
JS code for Visible on clicked event and invisible on unclicked event.
PatrickOllerton
hi,
Patrick
