18-Opal
Feb 21, 2018 9:48 PM UTC
Textured OBJ model works in iOS but not Android?
Hi Folks--
I'm working on some experiences using textures, as described in this thread. When I view the experience in the Preview window, or on iOS (iPad Pro), I can see the texture on the object. But when I view it in Android (Nexus 5x), I don't see the texture, just a shiny gray surface.
Is this a known limitation of Thingworx View on Android? Or is it something I'm doing wrong? Is there some way I could tweak the *.mtl file or something else to make it work on Android? Any suggestions appreciated!
--Clay
Feb 22, 2018 11:37 AM UTC
@ClayHelberg Is it possible to share the Obj file to reproduce and which Android, Studio version you are using ?
-Durgesh
18-Opal
Feb 22, 2018 5:28 PM UTC
Hi Durgesh--
A sample file (obj, mtl, & texture png) is attached. I made a very simple experience, and I see the texture in iOS, but not in Android. A different case using JPG for the texture image format gave similar results. Android version of Thingworx View is 8.2.0.1198. Please let me know if you need any additional information.
--Clay
18-Opal
Feb 22, 2018 5:29 PM UTC
Also, Thingworx Studio version is 8.2.0.2742.
--C
