18-Opal
March 2, 2017
The "hinge" problem
Hi folks--
Has anyone found a way with Thingworx Studio to have a "hinge" animation that works correctly? What I mean by that is, I want to rotate a part around another part or around an edge, the typical example being a door or hatch opening on a hinge.
I can build a beautiful animation of this in Creo Illustrate, and it looks fine in Creo View. But when I pull the same PVZ into Thingworx Studio, the hinge movement gets all weird. In Thingworx, the door or hatch begins in the correct location, and ends up in the correct location, but the rotation isn't right, so the door appears to detach from the hinge, do its rotation in mid-air, and then re-attach when it's done rotating.
I've tried a bunch of things, but nothing seems to work. It's difficult to troubleshoot, because as I mentioned, the animation looks correct in Illustrate and Creo View, but still doesn't work right in Thingworx.
If anyone has been able to make this work, how did you do it? Did you run into the problem I described above? If so, how did you get around it? Thanks.
--Clay
18-Opal
March 10, 2017
So, it turns out this was some kind of bug. The problem went away after the latest update (1.10). Thanks!
--Clay
What type of device is this being viewed through? Android, iOS or Windows?
If you have access to an iOS device do you experience the same issue?
18-Opal
March 2, 2017
Hi Marty--
Yes, it occurs on both iOS and Android versions.
--Clay
Another suggestion I have is to make sure you are using the high_optimized model
ClayHelberg18-OpalAuthorAnswer
18-Opal
March 10, 2017
--Clay
