Feb 23, 2023 3:53 PM UTC
ThingMark Experiences Launch at a Cant
We've been running into an issue lately where our HoloLens experiences that initiate via ThingMark launch with a slight-but-noticeable angle on the z-axis. We've been unable to figure out how to fix this or why this is happening. Has anybody else run into this issue?
Mar 9, 2023 10:12 AM UTC
Hi @Ike@ACE
I think it could be helpful the following points so check/clarify:
1.) Is the issue based on the specific thingmark print. Scale, print quality etc. - is the issue reproducible with other project (possible simplest project) with the same or different thingmark
2.) location , possible light conditions , environment
3.) using the same thingmark on mobile device , possibly similar configuration and check of IOS or Android have the same problem ( just as reference to compare)
4.) check the log. file if there are some errors  or warning - when you scan the thingmark. -> log file for specific device type according : https://www.ptc.com/en/support/article/CS283816
