Feb 8, 2019 6:17 AM UTC
Thingworx IoT data not updating in Vuforia view in Android
I have Installed Licensed Thingworx platform, Voforia Studio and Experience service. But the problem is
Thingworx IoT data not updating in Vuforia view in Android  as its working fine in "Preview" Section of
vuforia studio. Should we do any Modification in Subsystems in Thingworx? or should i create any remote things those kind of things??
After going so many Documents, Couldnt get required informations. Seeking for some guidance.
Thanks and regards,
Thrinath.
Feb 8, 2019 7:47 AM UTC
Are the services you mention installed as SaaS or on premise?
Are all of them HTTPS?
Is the Experience set to "Requires Authentication" under Configuration > Info > Access?
thrinath12-AmethystAuthor
Feb 8, 2019 8:08 AM UTC
Are the services you mention installed as SaaS or on premise? -Yes
Are all of them HTTPS? - No , we have set HTTP
Is the Experience set to "Requires Authentication" under Configuration > Info > Access?- No we given as Public
Feb 8, 2019 8:34 AM UTC
Hi @thrinath,
I think in your case it  could be helpful if you check the  following links info from the Viforia Studio Help
Configure Public Access to ThingWorx
(optional as addtional info ) Grant User Permissions
Feb 11, 2019 9:38 AM UTC
Now i am getting the IOT data in Mobile after given permissions in thingworx composer.
Feb 11, 2019 10:44 AM UTC
@thrinath  Thrinath,  as a note make sure you always set Visibility and Run time permission correctly on all the  TWX entities for which you need  to work inside Studio experiences to es-public-user .
-Durgesh
