TML widget X-ray shader
hi there,
I tried to apply x-ray shader on model Item with TML widget
<script name="xray_green" type="x-shader/x-fragment">
 precision mediump float;
 varying vec3 I;
 varying vec3 N;
 const float edgeFalloff = 1.0;
 const float intensity = 1.0;
 const float ambient = 0.2;
 void main() {
 vec4 color = vec4(0.1,0.9,0.3,1.0);
 float opacity = abs(dot(normalize(-N), normalize(-I)));
 opacity = ambient + intensity*(1.0-pow(opacity,edgeFalloff));
 gl_FragColor = opacity * color;
 gl_FragColor.a = opacity;
</script>
<script name="xray_green" type="x-shader/x-vertex">
 attribute vec3 vertexPosition;
 attribute vec3 vertexNormal;
 varying vec3 I;
 varying vec3 N;
 uniform mat4 modelViewProjectionMatrix;
 uniform mat4 modelViewMatrix;
 uniform mat4 normalMatrix;
 void main() {
 vec4 vp4 = vec4(vertexPosition,1.0);
 vec4 P = modelViewMatrix * vp4;
 I = P.xyz - vec3(0);
 N = vec3(normalMatrix * vec4(vertexNormal,0.0));
 gl_Position = modelViewProjectionMatrix * vp4;
</script>
and the result looks like
How do I get the details like this? https://www.youtube.com/watch?v=0UJt9mYSSis
Especially the surfaces inside the structure.
Any feedback would be appreciated. Smiley Happy
ClarK
Hello Clark,
I saw that the video in YouTube is done in Unity 3D.
  • Is it the same Shader used in your example and in the demo in Unity ?
I suppose that the answer is no because in the comments in YouTube, it is explained that :
  1. It needs 2 pass to have a such result
  2. We have a combination of source and destination colors
  3. Variables in Unity to control shader and the ones in you fragment shader are not the same
If I understand well your fragment shader, we have only one pass.
More details about the graphical result with 1 pass and 2 pass (In Unity 3D but it is common to all x-ray shaders)
https://lindenreid.wordpress.com/2018/03/17/x-ray-shader-tutorial-in-unity/
In OpenGL or WebGL, multipass shader doesn't exist.
It is 2 shaders to use. The second one is using the result of the first one.
I have this example about 2 shaders applied on 1 object in WebGL :
https://gist.github.com/philogb/3731312
But to be honest, I don't know how to port that into Vuforia Studio.
I don't think we have an access to WebGL API in javascript to control rendering pipeline.
I am asking to R&D to have more details.
Best regards,
Samuel
Hi Samuel,
Thank you for the reply.
And you are right about it, the answer to your question is "no".
I got the TML content form KTMBike_v2 project files.(https://share.ptc.com/sites/sales/ic/tdd/ves/content/ktm_cad/download.html)
Looking forward to the amswer.
ClarK
OK this info is here only as summary for people who are looking for the solution of this topic
To generate x-ray like in unity the following steps:
Create a TML Text  widget:
Edit the Text property and add the following  code:
 varying vec3 I;
 varying vec3 N;
 void main() {
 vec4 color = vec4(1.0,0,0,1.0);
</script>
 varying vec3 I;
 varying vec3 N;
 void main() {
</script>
Important is here in the code  e.g. the line for the color definition:
vec4 color = vec4(0,1.0,0,1.0);
Here means this for a green corlor.
If you want red color you can use
for blue color  :
vec4 color = vec4(0,0,1.0,1.0)
To use the shader  definition for a  modelitem -> define a modelitem and set in javaScript the shader property:
$rootScope.$on('modelLoaded', function() {
 $scope.view.wdg['modelItem-2']['shader'] = 'xray_green_ktm';
