Jun 12, 2020 9:13 AM UTC
Unable to connect to Experience Service (HTTPS protocol) with Android device
Hi there
Here is the situation
Thingworx 8.5.5 works with CERTIFICATE.JKS on Tomcat 8.5.43 (NOT a self-signed-certificate)
Experience Service 8.5.9 uses protocol HTTP, everything works
When trying to apply Certificate to Experience Service,
CERTIFICATE.JKS is converted to CERTIFICATE.PFX for usage.
start-es
results error (similar here: https://community.ptc.com/t5/Vuforia-Studio/Customer-used-to-Vuforia-Studio-OnPremise-before-and-tried-to/m-p/580637/highlight/true#M4610)
Error: unable to verify the first certificate
at TLSSocket.onConnectSecure (_tls_wrap.js:1473:34)
at TLSSocket.emit (events.js:311:20)
at TLSSocket._finishInit (_tls_wrap.js:916:8)
at TLSWrap.ssl.onhandshakedone (_tls_wrap.js:686:12) {
code: 'UNABLE_TO_VERIFY_LEAF_SIGNATURE'
start-es --allowssc would fire up Experience Service
Both https://<server>:2019/ExperienceService/ping
and https://<server>:2019/ExperienceService/id-resolution/resolutions/?key=urn:vuforia:nokey&resourcetype=Experience&wNdp=768&aspect=spatial-tracking works with TLS on desktop/iOS/Android
ISSUE
Using https://<server>:2019 for Vuforia View APP Experience Service URL
Everything works with iOS device
Not working with Android device: nothing in the Library, and "Whoops! Error loading Experience" message shows up when opening an experience
Same issue with PEM Certificate on Experience Service
Android logfile Error
javax.net.ssl.SSLHandshakeException: java.security.cert.CertPathValidatorException: Trust anchor for certification path not found.
Similar here: https://community.ptc.com/t5/Vuforia-Studio/Vuforia-View-does-not-pulling-the-experiences-from-On-Premises/m-p/615476/highlight/true#M6047
The Root CA is in the list of System Trusted credentials already.
Buy the way, no Cleartext issue in the logfile(https://community.ptc.com/t5/Vuforia-Studio/Vuforia-View-quot-Connection-Error-quot-while-scanning-the/m-p/597043#M5226)
How to resolve the issue?
Any reply is appreciated,
Thanks in advanded
SETUP(same macchine): JAVA 1.8.0_192-b12, Tomcat 8.5.43, TWX 8.5.5, ES 8.5.9, Android 9
Jun 24, 2020 1:36 PM UTC
Android devices are a little more particular about the certs they will allow if they aren't from a well known CA.
Check out this article: https://www.ptc.com/en/support/article/CS301678
Are you using a private organization CA? Do you have any intermediate certificates? If so, have you created a cert bundle?
Jun 29, 2020 6:34 AM UTC
Thanks for reply.
  • No intermediate certificates.
Nov 11, 2021 9:09 AM UTC
While unsuccessfully configuring the certificate for the Experience Service, it remains using HTTP only.
Use MED-61226-CD-XXX_SPX_es-X-X-X-bXXXX-XXX-windows-installer.exe which downloaded from https://support.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=VFS.
Modify
Then Use HTTP (No TLS)
After processing, in configuration.json shows
 "port": 2019,
 "realm": "ThingWorx",
 "httpsKeyPath": "",
 "httpsCrtPath": "",
 "httpsCaPath": null,
 "httpsPfxPath": null,
 "httpsCertPassphrase": "",
In Vuforia View, Experience Service URL is set to http://<server>:2019
