Jun 2, 2020 11:50 AM UTC
Unable to resize select widget in vuforia studio
I have a select box in the bottom of experience.
There is a row with 2 columns. The select box is in the left column. I am unable to resize the columns in 80/20 ratio so that the select box is bigger in size.
Can someone please suggest me css for the following issue.
Attached the screen shot
Jun 3, 2020 7:12 AM UTC
Hello Nberiwale,
You can use a such CSS style in List Widget :
.SelectSize {
 min-width: 280px;
Please find attached an example Project.
Best regards,
Samuel
nberiwale5-Regular MemberAuthor
Jun 8, 2020 9:26 AM UTC
Hi Samuel,
thanks for the reply.
I tried changes you suggested, they worked in a new project but are not working for the project I am working.
Even though i set the min-width as 280, the 2 columns are divided in exactly the same number of halves.
So the select box is taking only half the space on loading the experience.
I am attaching the project.  Could you please help me out.
Nazim
Jun 8, 2020 10:07 AM UTC
Hello Nazim,
It is needed to force the size of the Column in Grid Widget.
Without that, Select Widget is not displayed completly.
By the way, when using various screen size, we can see that this Select Widget is not perfectly displayed.
Some parts are outside the screen.
I suppose that it is needed to setup margin to solve that.
Best regards,
Samuel
