Nov 11, 2021 8:19 AM UTC
Using Alerts from Thingworx in Vuforia Studio
Hey Everyone! 🙂
I try to make a 3D-Panel visible as soon as an Alert in Thingworx occurs.
Example: I get the Temperature from an MQTT Broker. For that temperature I set an alert on >=20°C. Now I want to show a 3D Widget as soon as the alert is released in Thingworx. For that I added the alert as an event under external data in Vuforia Studio and then binded this alert to the 3D-Panel to show it.
Unfortunately this is not working as planned.
Can anyone support me?
Yours sincerely,
Marius
Nov 12, 2021 8:50 AM UTC
I know that this will be double work, but what if you bind the temp to the visible property of the panel with a filter.
return value > 20 ? true:false;
/Per
Nov 11, 2021 9:53 AM UTC
Article - "How to call ThingWorx service in Vuforia Studio using JavaScript": https://www.ptc.com/ru/support/article/cs299517
Nov 12, 2021 8:25 AM UTC
Hey Vladimir,
thank you for that information. I am wondering if there is no other solution. For example for properties you can use the service getPropertyValues, bind on of the properties inside to a text and get data pictured.
In my case, I want to make a panel visible as soon as the alert event is released from Thingworx. I hope to find a solution with easily binding the event of a service to the show function or the visibility of the panel.
/Per
Nov 15, 2021 7:37 AM UTC
Thank you! This is working 🙂
