Jan 13, 2021 1:25 PM UTC
using of $timeout
Hi everyone,
i am currently trying to make a HoloLense experience with two views, where i can switch between these views with a voice command.
I created an application event "Switch view" and linked it to the "Navigate" option of both views. This works fine, whenever i say "Switch view" it immediatelly switches.
But now i want to make this a little bit slower, with a delay of 1second for example. I tried to use $timeout but:
How do i use it and where do I have to write the command? (in Home.js or into the JS of the application event)
Thank you all for your help!
Jan 14, 2021 7:07 AM UTC
Here is another approach:
That's say we have 2 view, "first" and "second".
In first.js and second.js
$scope.app.switchView = function(destination){
 $timeout(function(){
 twx.app.fn.navigate(destination);
 }, 2000)
Then in APPLICATION EVENTS:
Voice Alias: switch to second view
JS: viewCtrl.app.switchView("second")
Voice Alias: switch to first view
JS: viewCtrl.app.switchView("first")
Jan 13, 2021 6:02 PM UTC
1. Let suppose you have 2 views Home / wich is the the start view and a second view named mySecondVIEW
2. Copy the below script in Home.js
$scope.app.mySecondViewCmd = function () { // will call the view "mySecondVIEW"
// with delay 2 secs
$timeout(function() {
 twx.app.fn.navigate("mySecondVIEW")
}, 2000); // call with delay of 2 seconds = 2000 miliseconds
3. In the js script of the second view in mySecondVIEW.js wirte the code:
$scope.app.myViewCmdHome = function () {
$timeout(function() {// will call the home view with 3 secs delay
 twx.app.fn.navigate("Home")
}, 3000); // call with delay of 3 seconds = 3000 miliseconds
4.) then for the voice command add in the js UI section the function call which should call mySecondView:
viewCtrl.app.mySecondViewCmd();
and for the voice command which should call  back the Home view:
viewCtrl.app.myViewCmdHome()
 I think the both defintions  of the functions  $scope.app.mySecondViewCmd() and  $scope.app.myViewCmdHome could be done in the start view (so that when this view was called then the definitions are available then)
 }, 2000)
Jan 14, 2021 8:10 AM UTC
Yes, this is better appraoch - more general- using only one deffinition. I see you confirmed that we need to define the function in each view.js - because I did this some time ago and could not remember if the voice command java code defintion will remember the defintion from the start view - also when we navigate to a second view.
Jan 14, 2021 9:04 AM UTC
Hi, @RolandRaytchev
Thanks for reply. I just try to provide a more general approach.
As to Function Declaration  part, here is the clarification:
With ".app",
Functions declared in one View can be used in any other Views.
e.g.
 }, 2000)
Without ".app"
Function can only works in the View in which was declared.
e.g.
$scope.switchView = function(destination){
 }, 2000)
In other words, $scope.app.switchView be declared in either View is sufficient in my approach above.
Sorry for misleading.
regards,
ClarK
