Jun 19, 2018 11:14 AM UTC
value change event of select widget
I want to use value change event of select widget,but tried with servral times and  get nothing.Does any body tried with it?
jxu2Answer
Jun 19, 2018 11:39 AM UTC
the question has been solved,pls refer to the former link for detail.
jxu210-MarbleAuthor
Jun 19, 2018 11:17 AM UTC
I also post it to Mr Clay at below:https://community.ptc.com/t5/Studio/What-is-the-format-for-quot-List-quot-in-the-Select-widget/m-p/550949#M3300
pls refer to the attatched exported file for the detailed code.
jxu210-MarbleAuthorAnswer
