Dec 3, 2025 6:08 PM UTC
vuforia error has accured
i cant start vuforia. i tried to delete and download it again, repair everything.
[2025-12-02T07:04:38.337Z] info: ==== Studio.exe 10.1.7.0 ====
[2025-12-02T07:04:38.403Z] info: Status Message: Anwendung wird aktualisiert
[2025-12-02T07:04:38.403Z] info: Removing files/folders from $0.0.0.0 $C:\Users\Metehan Jermaine\AppData\Local\VuforiaStudio
[2025-12-02T07:04:38.403Z] error: System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\Users\Metehan Jermaine\AppData\Local\VuforiaStudio'.System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\Users\Metehan Jermaine\AppData\Local\VuforiaStudio'.
at System.IO.Enumeration.FileSystemEnumerator`1.CreateDirectoryHandle(String path, Boolean ignoreNotFound)
at System.IO.Enumeration.FileSystemEnumerator`1.Init()
at System.IO.Enumeration.FileSystemEnumerator`1..ctor(String directory, Boolean isNormalized, EnumerationOptions options)
at System.IO.Enumeration.FileSystemEnumerable`1..ctor(String directory, FindTransform transform, EnumerationOptions options, Boolean isNormalized)
at System.IO.Enumeration.FileSystemEnumerableFactory.UserFiles(String directory, String expression, EnumerationOptions options)
at System.IO.Directory.InternalEnumeratePaths(String path, String searchPattern, SearchTarget searchTarget, EnumerationOptions options)
at System.IO.Directory.GetFiles(String path, String searchPattern, EnumerationOptions enumerationOptions)
at System.IO.Directory.GetFiles(String path)
at com.ptc.ThingworxStudio.MobileBuilderForm.CleanLocalAppData(String localAppData, List`1 excludeItems)
at com.ptc.ThingworxStudio.MobileBuilderForm.InitializeFiles(String localAppData)
at com.ptc.ThingworxStudio.MobileBuilderForm.StartServer(String extraArgs)
this is what the log says...
Dec 3, 2025 10:25 PM UTC
Have you checked if this directory actually exists: C:\Users\Metehan Jermaine\AppData\Local\VuforiaStudio
Dec 9, 2025 7:02 AM UTC
It doesnt exist.. Should i just create a folder with that name?
Dec 10, 2025 8:07 AM UTC
Yes.
