Feb 10, 2023 9:31 AM UTC
Vuforia Experience Service not accesible with second Laptop
Hello Community,
I have set up Vuforia Studio including the whole ecosystem on a private network. Here, unfortunately, I can not reach the server of Vuforia Experience Service via a second laptop.
When I try to ping the server through this link, it does not respond.
http<s>://<hostname>:<2019>/ExperienceService/ping
I can however access thingworx with the second laptop.
http<s>://<hostname>:<8080>/thingworx
I have already opened the ports in the firewall.
From the computer on which I have installed both software, both servers can be accessed without any problems. The problem is that I can not access the Experience Service with the second laptop on which I wanted to install Vuforia View.
Many greetings
Feb 28, 2023 9:28 AM UTC
Hello @QP_10574780 ,
Pls share the Studio logs and make sure that you are entering the correct URL.
Check this article for your reference:
https://www.ptc.com/en/support/article/cs340488
Also, try hitting the URL in another browser and let me know if it works for you.
Regards
Bhawna
May 2, 2023 1:50 AM UTC
Have you tried to access the experience server url using the ip-address?
looks like a name resolution issue.
