Feb 7, 2023 4:53 PM UTC
Vuforia - Kepserverex connection
Hello, I need to read tag values in Vuforia from KEPServerEX. Can it only be done from Thingworx or is there another option?
Feb 7, 2023 9:00 PM UTC
You can do http requests from studio. You need to enable rest in kW, you may need iot-gateway license to do so.
An issue I can see is the security issue, kepware runs with a connection to ot-network and letting phones/ipads connect to that is normally a no-no.
Feb 7, 2023 7:49 PM UTC
You can use the rest-server to get data from kepserver.
But you need to refresh the request manually to get the updates.
Per
anaclos14-AlexandriteAuthor
Feb 7, 2023 7:59 PM UTC
Thanks for your answer. Can it be done in Vuforia Studio? Or is another installation required?
