Jun 11, 2018 6:28 PM UTC
Vuforia studio authentication issue - Unable to login
I have noticed many others have flagged this issue but I cant seem to find a resolution in all the posts.
I have installed thingworx studio trial version 30 days trial period. When I'm trying to publish the project  it's asking for a "Authentication Required" pop-up. After giving the credentials, it is asking for the same authentication again and again.
Below is some code from the log.
Any help would be appreciated.
Kind Regards
Giuliano
Username : mr.ora.holo@gmail.com
[06/11/2018 19:12:30] warn: [twx-studio:gitUtils] nodegit is not installed.
[06/11/2018 19:12:36] info: [twx-studio:versionCheck] Version Check will use the update location: https://studio-download.vuforia.io/downloads/Studio.application
[06/11/2018 19:12:36] ar-extension version 8.3.0.3345 (1.26.1125)
[06/11/2018 19:12:37] info: [twx-studio:index] Studio Ready: listening on 127.0.0.1:3000
[06/11/2018 19:12:42] GET /home 200 33.967 ms - 3973
[06/11/2018 19:12:47] GET /libthingview_wasm.wasm 200 136.873 ms - 3973
[06/11/2018 19:12:51] GET /extensions/%7B%7B::projectType.imgPath%7D%7D 200 4.080 ms - 3973
[06/11/2018 19:12:51] GET /%7B%7B$root.currentProject.thingServerQRCode%7D%7D 200 5.899 ms - 3973
[06/11/2018 19:12:51] GET /extensions/%7B%7B::view.imgPath%7D%7D 200 5.845 ms - 3973
[06/11/2018 19:12:51] GET /extensions/%7B%7BviewType.imgPath%7D%7D 200 6.934 ms - 3973
[06/11/2018 19:12:51] GET /extensions/%7B%7B::w.image%7D%7D 200 8.307 ms - 3973
[06/11/2018 19:12:51] GET /libthingview_wasm.wasm 200 1.714 ms - 3973
[06/11/2018 19:13:57] GET /api/switch 401 6.531 ms - -
[06/11/2018 19:13:57] GET /api/switch 200 0.326 ms - -
[06/11/2018 19:13:58] GET /ExperienceService/viewcommandhost 200 680.003 ms - 24
[06/11/2018 19:14:59] info: [twx-studio:projectHelper] Building ves-ar-extension app: X7-2
[06/11/2018 19:15:12] info: [twx-studio:projectSettings] Notify preview windows: private-room-X7-2
[06/11/2018 19:15:12] GET /api/switch 200 0.383 ms - -
[06/11/2018 19:15:13] POST /api/publish/ 401 814.534 ms - -
[06/11/2018 19:15:30] POST /api/publish/ 401 381.222 ms - -
tmccombieAnswer
Jun 15, 2018 4:43 PM UTC
Thank you for the log file. I see you were able to auto-configure your instance without issue. The credentials used for auto-configure should be the same for validating/publishing. Are you using all lowercase when trying to validate/publish? These items are case sensitive. Have you tried MR.Ora.Holo@gmail.com as your username?
Jun 12, 2018 6:42 PM UTC
Are you able to validate the Experience Service without issue? You can do this under the 'info' tab of your experience.
Jun 12, 2018 6:57 PM UTC
Hi there,
That's for the reply.
I've gone to the info section.l selected validate. The field is populated with the trial URL. Clicked on validate and it asks me to sign in. I sign in but face the same issue with the sign in screen repeatedly popping up after I click on submit.
Many thanks
Jun 13, 2018 8:18 PM UTC
Please share your entire log file. This will help to determine root cause and a solution.
