Jan 13, 2021 6:13 AM UTC
Vuforia Studio Binding Filter Functions
Hi, I was planning to manipulate the data coming from Thingworx Service using the following:
return value.trim().replace("\"}]","").split("\":\"")[1]; with an example input being:  [{"result":"Data"}] . I want to implement this code in the binding filter but the output will contain nothing. Please help.
Jan 13, 2021 2:13 PM UTC
what kind of manipulation you want to see it ..............can you please elaborate it.
I tried to convert float value to integer coming from thingworx platform and i used following code. please check if it may help u
return $filter('number')(value,2);
Jan 14, 2021 7:45 AM UTC
To simulate Thingworx input, I create a Application Parameter:
TWX-input: [{"result":"Data"}]
Then bind to widget "valueDisplay-1"
Edit Filter: return JSON.parse(value)[0].result
In Preview
Is this meets you need?
