Mar 12, 2019 9:23 PM UTC
Vuforia View - Can't rotate/Move Object
Im doing the "Fundamentals of AR Development" training and im now stuck. At the end of the coffee machine exercise, the trainer try the created app in the PTC kitchen and he was able to rotate/move the object around on the counter no problem but its doesnt work for me and i followed every step. What i'm doing wrong ?
Thanks for the help
whityAnswer
Mar 13, 2019 7:47 AM UTC
Hi Subyforever,
please make sure, that you use a spatial target and that "Enable Scale Gesture" is selected. Also, you are asked to point the camera on a horizontal surface. When it is detected, you have to tap on the display in order to place the object.
Hope this helps
whity16-PearlAnswer
Hi Subyforever,
Hope this helps
Mar 13, 2019 2:20 PM UTC
Thank you for the help !
