Apr 29, 2019 7:31 AM UTC
what makes sequence took long time to load on HoloLens?
I've created animated sequence using Creo illustrate consists of 20 steps. I've managed and controlled the model transparency via Creo, such that I made all the parts transparent except for the animated one. It worked perfect as expected in preview, mobile and HoloLens. Only one issue appear in hololens, it took long time to load sequence, about 30 seconds! (in mobile phone takes a second).
Why it'd take that long time? how to reduce this time? the only option I have now is to download the experience to offline, which will cut the time to the half. but what if I want it online?
Any help or recommendations?
Apr 29, 2019 7:43 AM UTC
Did you apply the cad-optimizer? You recieve 4 Versions of the pvz-file. The ones you don't need should be deleted because they are downloaded every time the experience is loaded.
nqwifly1-VisitorAuthor
Apr 29, 2019 7:54 AM UTC
Yes, I used the lowest quality deleted the other ones. 30 seconds took for the low quality one to load.
Apr 29, 2019 8:06 AM UTC
Then maybe your model is too big. How many megabytes does it have? You could try to remove parts that you don't need.
