Aug 24, 2018 3:01 PM UTC
What's New in Vuforia Studio 8.3.3
Vuforia Studio
  • Support for Spanish locale
  • Model sequences can be applied at design time
  • Bug fixes and minor improvements
Vuforia View
  • HoloLens:
    • Support for model-based tracking
    • Support for sequence animations created with Creo Illustrate 4.1 and later
  • Windows:
    • Support for spatial tracking
      • NOTE: Currently only the Microsoft Surface Book and Microsoft Surface Pro 4 are supported.
Experience Service (On-Premises)
  • Support for Spanish locale for the installer
  • Model target generation as a service (Beta)
18-Opal
Aug 27, 2018 2:22 PM UTC
Thanks, Tara. Can you give a little more information about this item:
It's not clear to me what that means, or when I would want to use it (or not). Thanks.
--Clay
tmccombie21-Topaz IAuthor
Aug 27, 2018 3:51 PM UTC
Hi Clay,
This feature allows you to view your model during design as it will show in the experience based on the sequence selected. It is a check box found under the sequence selector for the model.
 model loaded into Studiomodel loaded into Studiosequence applied at design timesequence applied at design time
Hope this helps!
18-Opal
Aug 27, 2018 6:18 PM UTC
It does, thanks!
18-Opal
Aug 27, 2018 2:24 PM UTC
Also, a big THANK YOU to the dev team for getting Hololens support for newer versions of Creo Illustrate! Smiley Very Happy
Aug 27, 2018 7:16 PM UTC
@tmccombie Is the grouping of ModelItems under the parent Model new? This pretty big news on the large experience organization front!
Aug 31, 2018 3:21 PM UTC
@jmikesell yes, this is a new improvement to the 3D container.
Sep 6, 2018 6:22 PM UTC
@tmccombie it seems that with the new 3D container you can no longer drag modelItems in the tree to reorder them. Not drag them out of the 3D container but just reorder in the container. This is a loss of functionality that should be fixed.
Sep 1, 2018 5:04 AM UTC
Hi Tara,
I want to know about the following.
 thanks,
Preeti
Sep 3, 2018 7:11 AM UTC
It seems like after this update my Windows laptop does will not show me the camera anymore. I just get a black background.
I have tried resetting the app and uninstalling it but the problem persists. Any idea how to fix this? Or if there will be an update shortly to fix this issue?
Sep 10, 2018 6:10 AM UTC
Is anyone else experiencing an issue with Windows devices not showing the camera? We are having an issue as we are needing to demonstrate Vuforia from a Windows device.
Sep 10, 2018 11:51 AM UTC
I just tried an experience on a Surface Pro 3 with View 83.3.478.0 and it worked without problems.
