18-Opal
Apr 19, 2018 6:47 AM UTC
What types of widgets can I specify position?
The following css style is applied to the grid widget, but the button does not position well.
.pos {
margin-top: 30%;
height: 30ch;
When fixing the position of a widget, is it common to specify a position with a grid widget and then include the widget in it?
Any other good suggestions?
regards
tmccombieAnswer
Apr 19, 2018 3:02 PM UTC
Yes, it is recommended to use the grid widget to help with positioning of widgets.
tmccombie21-Topaz IAnswer
CHASEONHO18-OpalAuthor
18-Opal
Apr 20, 2018 5:38 AM UTC
If so, do you specify as many as% when specifying the location?
Or do you recommend positioning in px?
Apr 23, 2018 4:34 PM UTC
I have found specifying in px works well.
