Apr 10, 2020 10:49 AM UTC
Where is my color of the object target
Simple question: I don't see where I write the color of object target, the color of the model CAD don't catch inside 3D Model ? where is the function ?Screenshot_2.jpg
Apr 10, 2020 11:32 AM UTC
Hi @vincentdesign ,
I am not 100% sure, but I think here is the problem with the contract to the environment , some diffuse color will be not clearly determined by system as edges - when there are some tangent  silhouette of surfaces where is actually no real edge behind but it is depending on the view position and the distance.
I think you can check this information. It is about engine and implements more features as Studio but some basic are still the same  it is relevant also for Studio model targets
Please, check forllowing information:
https://library.vuforia.com/content/vuforia-library/en/features/objects/model-targets.html
https://library.vuforia.com/content/vuforia-library/en/articles/Solution/model-target-generator-user-guide.html
Apr 14, 2020 8:51 AM UTC
No I don't solve my problem, Is there a special soft Target Generator... ok, but I want to use my model 3D.
Apr 14, 2020 10:37 AM UTC
so far I know, in Studio we can use only the model Target widget. In the documents what I referred to - we should consider only the hints how to make it more readable - e.g. using colors.  May be , you can use a second model Widget (copy of the model) without diffuse coloring (e.g. the whole model is white ) to create the model Target.  You can later (after you created the model target) hide this model widget
