Oct 26, 2021 5:35 PM UTC
Try the following solution ( link: https://developer.vuforia.com/forum/android/play-youtube-video ), quote: "In class VideoPlayBack there is a method onSingleTapConfirmed put this code inside it and enjoy youtube or any link".
                boolean isSingleTapHandled = false;
                // Do not react if the StartupScreen is being displayed
                for (int i = 0; i < NUM_TARGETS; i++)
                    // Verify that the tap happened inside the target
                    if (mRenderer!= null && mRenderer.isTapOnScreenInsideTarget(i, e.getX(),
                        e.getY()))
                        if (i == 0)
                       Intent intra = new Intent(Intent.ACTION_VIEW);
                            intra.setData(Uri.parse("put ljnk here"));
                            startActivity(intra);
                        if (i == 1)
                            Intent intr = new Intent(Intent.ACTION_VIEW);
                            intr.setData(Uri.parse("put ljnk here"));
                            startActivity(intr);
                        if (i == 2)
                            Intent intr1 = new Intent(Intent.ACTION_VIEW);
                            intr1.setData(Uri.parse("https://yput ljnk here"));"));
                            startActivity(intr1);
                        //------ FUllScreen remove.... just uncomment  the below code
                        // Check if it is playable on texture
                       /* if (mVideoPlayerHelper[i].isPlayableOnTexture())
                            // We can play only if the movie was paused, ready
                            // or stopped
                            if ((mVideoPlayerHelper[i].getStatus() == MEDIA_STATE.PAUSED)
                                || (mVideoPlayerHelper[i].getStatus() == MEDIA_STATE.READY)
                                || (mVideoPlayerHelper[i].getStatus() == MEDIA_STATE.STOPPED)
                                || (mVideoPlayerHelper[i].getStatus() == MEDIA_STATE.REACHED_END))
                                // Pause all other media
                                pauseAll(i);
                                // If it has reached the end then rewind
                                if ((mVideoPlayerHelper[i].getStatus() == MEDIA_STATE.REACHED_END))
                                    mSeekPosition[i] = 0;
                                mVideoPlayerHelper[i].play(mPlayFullscreenVideo,
                                    mSeekPosition[i]);
                                mSeekPosition[i] = VideoPlayerHelper.CURRENT_POSITION;
                            } else if (mVideoPlayerHelper[i].getStatus() == MEDIA_STATE.PLAYING)
                                // If it is playing then we pause it
                                mVideoPlayerHelper[i].pause();
                        } else*/ if (mVideoPlayerHelper[i].isPlayableFullscreen())
                            // If it isn't playable on texture
                            // Either because it wasn't requested or because it
                            // isn't supported then request playback fullscreen.
                            mVideoPlayerHelper[i].play(true,
                                VideoPlayerHelper.CURRENT_POSITION);
                        isSingleTapHandled = true;
                        // Even though multiple videos can be loaded only one
                        // can be playing at any point in time. This break
                        // prevents that, say, overlapping videos trigger
                        // simultaneously playback.
                        break;
                return isSingleTapHandled;
Oct 27, 2021 6:46 AM UTC
Hi @RG_10041320 ,
the simples way could be to try to use thje  video widget according to the help documentaion:
http://support.ptc.com/help/vuforia/studio/en/#page/Studio_Help_Center%2FWidgetVideo.html
and usage of remote media:
http://support.ptc.com/help/vuforia/studio/en/#page/Studio_Help_Center%2FSetRemoteMediaBindings.html%23wwID0EGG1S
