Apr 1, 2021 4:23 PM UTC
3D-Guided Service Instructions Tutorial
The new 3D-Guided Service Instructions example use case walks you through creating a Vuforia Studio Experience that will allow a frontline worker to:
  •  Find the physical location of a broken part on an object using a digital model
  •  Search for parts on a 3D model of the object
  •  Find and order replacement parts from a vendor using a persistent shopping cart
The 3D-Guided Service Instructions use case will walk you through the following sections:
