Jun 7, 2019 1:45 PM UTC
List of Vuforia Studio events which we could be used as listener by javaScript/angular.js
Unfortunately, in the Vuforia Studio Documentation there is no complete List with the possible events which could be handled JS.
Therefore for the first time this article tries to provide additional Information about known events :
1.) modelLoaded - is not required any more because the UI allow directly to specify this event.
$rootScope.$on('modelLoaded', function() {
 //do some code here
2.) Step completed example:
scope.$on('stepcompleted', function(evt, arg1, arg2, arg3) {
 var parsedArg3 = JSON.parse(arg3);
console.log("stepcompleted stepNumber="+parsedArg3.stepNumber + " nextStep="+parsedArg3.nextStep);
$scope.app.stepNumber=parseInt(parsedArg3.stepNumber);
$scope.app.nextStep=parseInt(parsedArg3.nextStep);
$scope.app.duration=parseFloat(parsedArg3.duration);
3.) Event - stepstarted:
$scope.$on('stepstarted', function(evt, arg1, arg2, arg3) {
 console.warn(arg3);
 console.log("stepstarted stepNumber="+parsedArg3.stepNumber);
Please, pay attention that on some platforms will not provide complete information  in stepstarted. So, In this case the complete info is available in 'stepcompleted' – the best is to test it.
4.) after entering in  a view in studio (e.g. Home ...):
$scope.$on('$ionicView.afterEnter', function() {$scope.populateModelList();
5.) click/tap event on the current panel:
$rootScope.$on('click', function() { tapCount++;console.log("click event called");} );
or  with coordinates
document.addEventListener('click', function(event) {console.log("click() 1 called");
 $scope.lastClick = {
 x: event.pageX, y: event.pageY};
you can also see this topic.
6.) New step  -example:
$scope.$on('newStep', function(evt,arg) {
 var getStepRegex = /\((\d*)\//;
 console.log(arg);
 console.log( getStepRegex.exec(arg)[1]);
//check what it prints to the console - the step number }); ...
 7.) Here is also  a more advance construct- it defines a userpick event e.g. for all models widgets:
 angular.forEach($element.find('twx-dt-model'), function(value, key) {
 // search all twx-td-model's -> means all model widgets
 angular.element(value).scope().$on('userpick',function(event,target,parent,edata) {
 //for each model widget will set a userpick listener
 console.log('edata');console.warn(edata);
	 console.log("JSON.parse(edata)");console.warn(JSON.parse(edata));
 	 	var pathid = JSON.parse(edata).occurrence;
	 $scope.currentSelection = target + "-" + pathid;
// this is the current selection - the selected component occurence
// you can use it for example as shown below
// try{
//tml3dRenderer.GetObject($scope.currentSelection).GetWidget().ApplyOccludeOpacity(OCLUDE_VAL,OPACITY_VAL);
//} catch (e1234) {$scope.view.wdg['3DLabel-4']['text']= "e 1234exception in GetObject.GetWidget..."; }
// } ) //end of the userpick defintion } ) //end of for each funciton
 8.) tracking event:
$scope.$on('trackingacquired', function (evt,arg) {
 // alert('didStartTracking');
 // this is not really needed
 $scope.message = parseInt($scope.app.params["currentStep"]);
 $scope.$apply();
$scope.$on('trackinglost', function (evt,arg) {
 // alert('didFinishTracking');
 $scope.message = "Scan the ThingCode with your camera.";
 $scope.$apply();
9.) popover event:
var my_tmp = '<ion-popover-view><ion-header-bar> <h1 class="title">My Popover Title</h1> </ion-header-bar> <ion-content> My message here! </ion-content></ion-popoverview>';
$scope.popover= $ionicPopover.fromTemplate(my_tmp, { scope: $scope });
$ionicPopover.fromTemplateUrl('my-popover.html', { scope: $scope }).then(function(popover) { $scope.popover= popover; });
$scope.openPopover= function($event) { $scope.popover.show($event); }; $scope.closePopover= function() { $scope.popover.hide(); }
//////////////destroy popover
 $scope.$on('$destroy', function() { $scope.popover.remove(); });
/////// hide popover
$scope.$on('popover.hidden', function() { // your hide action..
 // on remove popover
$scope.$on('popover.removed', function() { // your remove action
10) watch event -watches are created using the $scope.$watch() function. When you register a watch you pass two functions as parameters to the $watch() function: 1)A value function 2)A listener function
When the value returned by function 1.) changes - this lead to execution of the funciton 2.)
Example:
$scope.$watch(function(scope) { return $scope.view.wdg['label-1']['text'] },
// watches if change for the the text of label-1
//when changes then play a step for model-1
	function() {
 	console.log($scope.view.wdg["model-1"]);
 		$scope.view.wdg["model-1"].svc.play;
11.) Camera tracking - make sense only on mobile device- no sense for preview mode!
//// define tracingEvent only on end device
tml3dRenderer.setupTrackingEventsCommand (function(target,eyepos,eyedir,eyeup) {
 // $scope.view.wdg['3DLabel-1']['text']="eyepos=("+eyepos[0].toFixed(2)+","+eyepos[1].toFixed(2)+","+eyepos[2].toFixed(2)+")";
 $scope.app.params['target']=target;
 $scope.app.params['eyepos']="eyepos=("+eyepos[0].toFixed(2)+","+eyepos[1].toFixed(2)+","+eyepos[2].toFixed(2)+")";
 $scope.app.params['eyedir']="eyedir=("+eyedir[0].toFixed(2)+","+eyedir[1].toFixed(2)+","+eyedir[2].toFixed(2)+")";
 $scope.app.params['eyeup'] ="eyeup =("+ eyeup[0].toFixed(2)+","+ eyeup[1].toFixed(2)+","+ eyeup[2].toFixed(2)+")";
},undefined);
 } //end device
12.) There is also a sequenceloaded event, which is useful if you have a model with multiple sequences defined, and you are switching sequences dynamically in the experience.
$scope.$on("sequenceloaded", function (evt, arg) {
 console.log("sequence loaded, starting play");
 $scope.setWidgetProp("loading","visible",false);
 $scope.app.fn.triggerWidgetService("model-1","playAll");
In this point is  here a good feedback comming from advance user (expert) :
If you grep for "$emit" through a project folder, you can turn up the following event names:
  • valueacquired (bar code scanner)
  • usercanceled (bar code scanner)
  • tracking
  • modelloadfailed
  • sequenceloaded
  • newStep
  • playstarted
  • sequenceacknowledge
  • playstopped
  • sequencereset
  • onReset
If you grep for "$on(", you can find some additional ones:
  • trackingacquired
  • trackinglost
  • modelLoaded
  • click
  • app-fn-navigate
  • app-fn-show-modal
  • app-fn-hide-modal
  • $ionicView.afterEnter
  • $stateChangeStart
  • loaded3DObj
  • loadedSeqErr
  • loadedSeq
  • $destroy
  • select3DObj
  • move3DObj
  • loadError3DObj
  • readyForZoom3DObj
  • serviceinvoke
  • stepstarted
  • stepcompleted
  • twx-entity
  • twx-service-input
  • twx-service-name
This is a  good point and it seems that this list contains the most of the possible events.
Events Handling Feedbacks from EXTERNAL DATA  services
Such event is    the twx-service complete event. This event is called when we call a service registered in the external data and the service is completed.
Here an example (also mention in the post😞
Here in the example in the external data the service LoadJSON was added.
$scope.GetJsonFromTwxRepository = function(path) {
 $scope.$applyAsync(function() {
 $rootScope.$broadcast('app.mdl.CAD-Files-Repository.svc.LoadJSON',
 {"path":path}
 );} ,500 );
 $scope.app.speak("after call of GetJsonFromTwxRepository")
//in the modelloaded listener register
// LoadJSON-complete event -> to laod the data into session
 $scope.$root.$on('LoadJSON-complete', function(event, args) {
console.log("LoadJSON-complete event");
$scope.COMP_LOCs=args.data
console.log(JSON.stringify( $scope.COMP_LOCs))
So the code above shows how to call from JavaScript the service added to the external data. This service should return the called JsonObject. The call is asynchronously so that when  thingworx  will come back the listener 'LoadJSON-complete' will be called and here will print the content of the JsonObject to the console.
Here the listener is registered inside the modelload event (this is event is coming late – so to be on the save side that everything is already initialized)
This is generally that you for any Thingworx services added to the External data <your_twx_service_name>-complete
the arg.data contains then the data which should be returned by the method.
