Emeritus
Service for creating of Bom - and Viewable Lists from json files
In this article  I want to consider the question how to   define a  TWX service, which could create   a  Bom and Viewable Lists from  json files. This will be very helpful option when we want to display some CreoView data in  Thingview.
How to extract BOM and viewable data form a Creo View /Illustrate *.pvz file is shown in the post "How to extract the components with properties from a pvz file".
In this example the json files are saved already  in a thingworx repository (means a thing form template FileRepostiroy) e.g.  "CAD-Files-Repository" :
1.)Create a service for the BOM List /InfoTable
  • edit the CAD-Files-Repository thing and create a new service named  "GetBomStruct_arg_path"
  • set  the BaseType : INFOTABLE .
  • Set the DataShape property of the service - > here to BomListStuct -> this datashape need to be created  first . It should have the following Fields / property (all String type):
  • create a service input parameter "the_json_path". Using this parameter we can past the repository path to the service
  • edit the java script . We can past the following script (see the comments in the script area)
var params = {
	path: the_json_path /* STRING */
// path it set to the input argument
// example for such setting value
// --> "/json_lists/Machine-complete-CV.PVZ-bomlist.json"
var Content = Things["CAD-Files-Repository"].LoadJSON(params);
//This will call the method LoadJSON(params) of the thing CAD-File-Reposistory
var params1 = {
infoTableName: undefined /* STRING */,
dataShapeName: "BomListStruct" /* DATASHAPENAME */
// result: INFOTABLE
var jsonTable = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params1);
var result = DataShapes.ThingviewBomData.CreateValues();
// working fine
for(i in Content.array){
 jsonTable.AddRow({Part:Content.array[i].part,
 Description:Content.array[i].description,
 sBOMDepth:Content.array[i].sBOMDepth,
 sBOMID:Content.array[i].sBOMID,
 sBOMIDPath:Content.array[i].sBOMIDPath,
 sBOMName:Content.array[i].sBOMName,
 sBOMPath:Content.array[i].sBOMPath,
 path:Content.array[i].sBOMIDPath,
 parentPath:Content.array[i].sBOMIDPath.substring(0,Content.array[i].sBOMIDPath.lastIndexOf('/'))
result = jsonTable;
The parentPath  infoTable field is required for Tree Widget  to display the BOM list as tree
The following code:
{ jsonTable.AddRow(Content.array[i]);}
the  code above will transfer  1 to 1  all  fields defined  in the json file with data into  infoTable fields. In this case  is not used because we have different mapping for "parentPath" -> it is new in the output InfoTable and is not contained by the json file.
Test the  service:
2.)Create a service for the BOM List /InfoTable (steps are similar to 1.)
  • edit the CAD-Files-Repository thing and create a new service named  "getViewableList_arg_path"
  • set  the BaseType : INFOTABLE . Set the DataShape property of the service - > here to viewablelist_new -> this datashape need to be created  first . It should have the following Fields / property (all String type)
  • Create a service input parameter "the_json_path". Using this parameter we can past the repository path to the service
  • Edit the java script . We can past the following script (see the comments in the script area):
var params = {
	//path: "/json_lists/Machine-complete-CV.PVZ-viewablelist.json" /* STRING */
var params1 = {
dataShapeName: "viewablelist_new" /* DATASHAPENAME */
 jsonTable.AddRow({name:Content.array[i].name,
 //type:Content.array[i].description,
 type:"viewable",
 value:Content.array[i].value,
 hasAnimation:Content.array[i].hasAnimation,
 hasSequence:Content.array[i].hasSequence
result = jsonTable;
  • Test the  service:
