olivierlp
Community Manager
May 14, 2021
Best Answer
  • May 14, 2021
  • 0 replies
  • 10188 views
We love answers!
You have made it so far! Let's talk about one of the critical things to do on the PTC Community: mark a reply as a Best Answer.
When you start a topic, you will receive replies from other members. When one of the replies is a solution to your initial inquiry, you should accept it as a Best Answer. Just in case, we will send you an automatic reminder after a few days for you to check the replies on your topic.
Why should you consider marking a Best Answer?
Consider that someone took the time to look at your post and reply. A little acknowledgement goes a long way with marking a reply as a Best Answer if the suggestion works for your problem. Of course, a post to thank or further the conversation is a plus and always appreciated!
Additionally, posts with a Best Answer are returned with a higher preference by search engines on the Community. You will signal a greater value for your conversation by marking an answer. This is a strong contribution to the entire Community!
Last updated by Catalina, April 2026
