可视化缓慢
  • April 21, 2025
  • 2 replies
  • 369 views
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS11
配置了3台CAD可视化服务器,但是三台运行的数据量差距大,最快的一天跑了600条数据,最慢的一天只有130条
Here are the errors that I faced
无
AndrewK
Community Manager
April 21, 2025
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • Could you provide details about the hardware specifications of the three CAD visualization servers?
  • Are there specific times or conditions under which the data processing speed varies significantly? For example, peak usage times or specific types of data being processed.
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
avillanueva
23-Emerald II
April 21, 2025
Publishing rates will be dictated by the size of the data that they are processing. It is scalable so you can add more workers  if you know that you will be processing lots of data in batch then scale them down. There are lots of articles and posts on managing this. But fundamentally, if you hit a patch of large assemblies and drawings, publishing rates will slow down compared to single piece parts or simple drawings. There is now way to managed that unless you do some advanced pre-publishing, blocking or other rules. I had asked many years ago if PTC could do a pre-look to ID large assemblies and direct them to a special worker so as not to clutter the other ones. No answer yet on that.
