카티아 도면 변환 실패
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.0
카티아 파일을 dwg로 변환시 모든 파일에 대해 $ERROR$ Can not open document 에러 표시되며 변환되지 않습니다.
Here are the errors that I faced
2026-10-15 16:45:21 CAD 에이전트 응답 $DONE$ C:\ptc\catdrw2dwg\dwg_tmp\w2i1j54\2049-10-103_SADDLE.dwg 전송 중
2026-10-15 16:46:43 'RUN' 요청 prepareForConversion final message = > $RUN$ 2049-05-101_HEAD_BODY catdrawing master_rep 6 C:\ptc\catdrw2dwg\dwg_tmp\w2i1j55 C:\ptc\catdrw2dwg\dwg_tmp\w2i1j55 :> <>을(를) 받았습니다.
2026-10-15 16:46:43 명령 C:\ptc\catdrw2dwg\bin\worker4dwg.bat C:\ptc\catdrw2dwg\logs\1792050403490.in C:\ptc\catdrw2dwg\logs\1792050403490.out을(를) 실행 중
2026-10-15 16:46:43 기다리는 중 ....
2026-10-15 16:48:06 완료됨
2026-10-15 16:48:06 CAD 에이전트 응답 $DONE$ C:\ptc\catdrw2dwg\dwg_tmp\w2i1j55\2049-05-101_HEAD_BODY.dwg 전송 중
2026-10-15 16:49:24 'RUN' 요청 prepareForConversion final message = > $RUN$ 2049-10-373_BRACKET(Z) catdrawing master_rep 6 C:\ptc\catdrw2dwg\dwg_tmp\w2i1j56 C:\ptc\catdrw2dwg\dwg_tmp\w2i1j56 :> <>을(를) 받았습니다.
2026-10-15 16:49:24 명령 C:\ptc\catdrw2dwg\bin\worker4dwg.bat C:\ptc\catdrw2dwg\logs\1792050564534.in C:\ptc\catdrw2dwg\logs\1792050564534.out을(를) 실행 중
2026-10-15 16:49:24 기다리는 중 ....
2026-10-15 16:49:50 완료됨
2026-10-15 16:49:50 CAD 에이전트 응답 $DONE$ C:\ptc\catdrw2dwg\dwg_tmp\w2i1j56\2049-10-373_BRACKET(Z).dwg 전송 중
2026-10-15 16:50:22 'RUN' 요청 prepareForConversion final message = > $RUN$ 2710-75-101_MAIN_COVER(R) catdrawing master_rep 6 C:\ptc\catdrw2dwg\dwg_tmp\w2i1j57 C:\ptc\catdrw2dwg\dwg_tmp\w2i1j57 :> <>을(를) 받았습니다.
2026-10-15 16:50:22 명령 C:\ptc\catdrw2dwg\bin\worker4dwg.bat C:\ptc\catdrw2dwg\logs\1792050622540.in C:\ptc\catdrw2dwg\logs\1792050622540.out을(를) 실행 중
2026-10-15 16:50:22 기다리는 중 ....
2026-10-15 18:02:33 완료됨
2026-10-15 18:02:33 CAD 에이전트 응답 $ERROR$ Can not open document 전송 중
