Jan 28, 2015 8:08 AM UTC
10.2: Can't select phases in "Life Cycle Template Admin" with java 1.8
Hello to all,
after the installation of Java 1.8 client, we can't select phases of an "Advanced" Lifecylce in the "Life Cycle Admin".
We can create new phases and can also select the new phases, but existing phases dosn't work.
- Windchill 10.2 M020
- Client: Win7, 64bit, Java 1.8.0.31
Best regards
Ralf Klusmann
jesshAnswer
Jan 28, 2015 11:33 AM UTC
Java 8 clients will be supported as of M030, which is scheduled for FCS in less than a month. The issue you've encountered is a known issue with Java 8 that has been resolved in M030.
Java 8 will not be supported on the server until the next release.
Jan 28, 2015 8:41 AM UTC
Your problem there is Java 1.8, which is not supported until I think 10.3.
You will have to roll back to 1.7 I am afraid unless anyone has any workarounds.
jessh12-AmethystAnswer
