Dec 17, 2015 5:07 PM UTC
10.2 M030 CPS10 - Has anyone been able to compile the CATIA V5-6R2015 WGM Abstraction dll's?
We have just updated our TEST System to 10.2 M030 CPS10 (only released today) and I am trying to compile the CATIA V5 Abstraction dll's for the WGM.
I have successfully compiled dll's for CATIA versions 18 to 24, but version 25 fails with the error saying "ERROR - Abstraction or loader files don't exist"
It seems a bit strange when setting up the compilation environment as the CATVBTsetup command does not show a Visual Studio checkbox, only showing an Eclipse/IBM Rational Applications one, which I think is indicative that something is wrong (presumably with the CATIA / API / RADE) software - but I have tried this with both GA and SP3 versions of the CATIA software and get the same issue. In which case, others should be seeing this problem too.
I have logged a call with PTC, but was wondering if anyone else had seen this?
Rgds
Gary
Dec 18, 2015 5:07 PM UTC
OK, just to close this out in case others have had trouble with this - I got the following response from PTC Tech Support:
After deeper investigation, For CATIAV5 R2015 and later , Microsoft Visual Studio 2012 Update 4, with the following patches is required :
- KB2929731
- KB2957527
- KB2969618
Hopefully they will update their documentation to reflect this soon, so no one else gets caught out by this.
Rgds
Gary
GaryMansell12-AmethystAuthorAnswer
- KB2929731
- KB2957527
- KB2969618
Rgds
Gary
Dec 21, 2015 3:34 PM UTC
A further note: with this version, it appears that you don't need to run the CATVBTSetup.exe command to configure the VS2012 installation for CAA like you did with all the previous versions.
After installing all the software, just run CATVBTLicenser.exe and select the CDV license and apply it, then run the Builder program and out pops the Abstraction dll's as if by magic.
Dec 21, 2015 4:39 PM UTC
Hi Gary,
Thank you for posting all these information. I really appreciate that.
For CATIA V5-R2015 or later, Microsoft Visual Studio 2012 Update 4 is required to build CATIA Abstraction Libraries for PTC Windchill Workgroup Manager for CATIA V5.
Also the following patches are required.
The necessary steps prior to building the Catia Abstraction Library are documented in CS108640
CATVBTSetup Command is recommended step to configure CAA RADE Tools and enable add-ins and macros, but it is not mandatory step to build CATIA Abstraction Libraries via CATIA Abstraction Builder. PTC is working on creating a Technical Support Article to provide these information. Once it is available I will post it into this discussion topic.
CATIA V5-6R2015 is also supported with PTC Windchill 11.0 F000, where the installation process of PTC Windchill Workgroup Manager for CATIA V5 has changed. For the information, our customers can refer to a video (Tutorial: Creating the CATIA V5 Abstraction Library (PTC Windchill Workgroup Manager for CATIA V5)) in PTC learning exchange site.
Yoda
Aug 5, 2016 7:12 AM UTC
Dear all,
thank you so much for these tips. I'm builing dlls and I have some doubds on the configuration of Windows/Visual Studio.
I'm able to build them but what is expected I use to do that?
Do I need to install all the Microsoft hotfix for Windows 7 Sp1?
Do I need to install only VStudio2008Sp1 patches in the video or it is better to install everything Windows Update propose?
I tried different configuration and MD5 of dll is changing everytime i install patches, so i'm little bit confused on that.
Thank you for the answers
Andrea
ps i'm building dlls for CATIA V5-6R2014 SP4
