May 28, 2016 12:36 PM UTC
2d drawings using Windchill mobile
Is it possible to view 2D drawings (.plt) using Winchill Mobile? If not, what is the best way to view .plt files from Windchill on an iPad?
May 31, 2016 8:26 PM UTC
right now we're looking at a custom cad worker to convert autocad to pdf. then place the pdf as the default representation of the object. WE're exploring this right now. DWG Converter - Batch Convert DWG to PDF,EPS,CGM,SVG,PLT,TIFF... due to the command line support. With any luck we should be done Friday.
Jun 20, 2016 6:22 PM UTC
Hi Steve,
I'm not sure if I understood, PTC will use DWG Converter?
