3D drawing conversion (publish) error: "W:\\w2i1jXX directory creation problem"
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.1.2
[Symptom]
- 3D CAD (.prt/.asm) publish fails with $ERROR$; no Creo View representation is generated.
- Publish log: "no available connected worker" -> "starting new worker WKP02-PROE:1" -> error, publish ends.
- MethodServer log shows repeated errors (WorkerSet: PROE3D):
ERROR wt.wvs.workeragent.Worker - W:\\w2i1jXX directory creation problem. A file with the same name already exists or you do not have write permission.
(suffix increments per attempt: j14 -> j15 -> j16 ... j24 -> j25 -> j26)
- PublisherQueue retries the failed job about every minute.
- 2D (PROE2D on WKP01) works normally.
[Environment]
- Windchill 12.1.2.7 (no patches installed), Creo Parametric 10.0.4.0, Creo View Adapters 10.1.0.0
- On the Windchill server: W: -> \\WKP02\share (3D worker), X: -> \\WKP01\share (2D worker)
- Worker config: localpath=W:\, remotepath=E:\share, queueset=PROE3D
[Checked]
- W: mapping OK, folders can be created manually on W:, share/NTFS permissions identical to 2D, enough free space, no leftover folders in W:
[Request]
Please help identify the cause and solution.
