9.1 to 10.0 Change in Functionality AutoNumbering
Hello
In 9.1 if you AutoNumber then by default it could not be changed... there is an OIR constraint protecting it. If an Orgadmin hit Rename they could not change the number.... If you want to allow it you could remove the constraint.
In 10.0 you can Rename by Default as orgadmin..... And no reference in the OIR.
Has anyone investigated how to get 10 to act like 9.1? NO User by Default should be able to Change the Auto-Generated Number for a Windchill Part.
Anyone know why PTC Changed the Default Behavior?
Brian Sullivan
Brian Sullivan
