Jun 13, 2024 3:09 AM UTC
A physical folder corresponding to the root folder mount path "C:\vault\vault1" does not exist.
Mount a folder to the new root folder of the replica fails with the following error message:
Create mount for root folder "vault1" failed. Nested exception is: wt.util.WTException: Creation of subfolder below root folder "vault1" failed. A physical folder corresponding to the root folder mount path "C:\vault\vault1" does not exist.
The following error messages are thrown in methodserver.log:
ERROR : wt.wrmf wcadmin - Message: Resource bundle/Message key = wt.wrmf.delivery.deliveryResource/18
(wt.wrmf.delivery.deliveryResource/18) wt.wrmf.delivery.WTDeliveryException: Can not invoke the method "addRemoteAutoFolder" declared in class "wt.fv.replica.StandardReplicaService".
at wt.wrmf.delivery.StandardReceiverService.returnExecutionAlert(StandardReceiverService.java:862)
at wt.wrmf.delivery.StandardReceiverService.executeMethod(StandardReceiverService.java:630)
at wt.wrmf.delivery.StandardReceiverService.processActionShippingItem(StandardReceiverService.java:1120)
at wt.wrmf.delivery.StandardReceiverService.pickUpMessageBiDi(StandardReceiverService.java:455)
at wt.wrmf.transport.httptransport.HTTPPipeAdapter.performPushInGeneral(HTTPPipeAdapter.java:617)
at wt.wrmf.transport.httptransport.GZIPHTTPPipe.acceptHttpTransWithResump(GZIPHTTPPipe.java:294)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at wt.httpgw.HTTPServer.processRequest(HTTPServer.java:346)
at wt.httpgw.MethodRequestHandler.handleRequest(MethodRequestHandler.java:58)
at wt.httpgw.HTTPGatewayServlet.serviceWithoutFilters(HTTPGatewayServlet.java:336)
at wt.httpgw.FilterChainImpl.doFilter(FilterChainImpl.java:94)
at wt.session.SessionContextDestroyer.doFilterInternal(SessionContextDestroyer.java:136)
at wt.session.SessionContextDestroyer.doFilter(SessionContextDestroyer.java:184)
at wt.httpgw.FilterChainImpl.doFilter(FilterChainImpl.java:81)
at wt.httpgw.HTTPGatewayServlet.service(HTTPGatewayServlet.java:235)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:733)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
at com.ptc.jws.servlet.filter.WsdlServletFilter.doFilter(WsdlServletFilter.java:61)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
at com.ptc.core.ui.validation.URLValidationFilter.doFilter(URLValidationFilter.java:77)
at wt.httpgw.filter.WTContextBeanFilter.doWithWtContextBeanHandler(WTContextBeanFilter.java:104)
at wt.httpgw.filter.WTContextBeanFilter.doFilter(WTContextBeanFilter.java:58)
at wt.servlet.CompressionFilter.doFilter(CompressionFilter.java:294)
at wt.servlet.RequestInterrupter.doFilter(RequestInterrupter.java:335)
at wt.servlet.ServletRequestMonitor.doFilter(ServletRequestMonitor.java:1660)
at wt.servlet.ServletRequestMonitorFilter.doFilter(ServletRequestMonitorFilter.java:56)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:544)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:143)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:364)
at org.apache.coyote.ajp.AjpProcessor.service(AjpProcessor.java:526)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:831)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1639)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:748)
ERROR : wt.fv.StandardFvService wcadmin - Creation of subfolder below root folder "vault1" failed. A physical folder corresponding to the root folder mount path "C:\vault\vault1" does not exist.
ERROR : com.ptc.windchill.vaulting.rest.MountResource wcadmin - (wt.fv.fvResource/54) wt.util.WTException: Create mount for root folder "vault1" failed.
The following is part of my configuration(replica):
java.rmi.server.hostname=l00683a.XXXX.com
wt.intersvrcom.masterSite.1=http\://windchill.XXXX.com/Windchill/servlet/WindchillGW,C\:\\vault\\master.pubkey
URL:http://l00683a.XXXX.com/Windchill/servlet/WindchillGW
    Jun 17, 2024 7:01 AM UTC
    No, not for that reason. I have found the problem,.is the host name and URL do not match.Thanks.
    HelesicPetr
    Jun 14, 2024 10:31 AM UTC
    Hi @ZL_10908440
    Try to create the folder manually
    PetrH
    ZL_1090844010-MarbleAuthorAnswer
