18-Opal
Sep 7, 2017 4:48 AM UTC
About Windchill External Connection
Hi I'm SeonHo
Windchill is running on one PC.
On other PCs that share a single router, they can access Windchill by modifying the hosts file.
Another PC using another Internet network [another router or another LAN] is not accessible to Windchill.
Through the port forward rule, I set the external IP & the external port to the internal IP[IP on windchill installed PC] & the internal port.
The internal IP used is the IP of the PC with Windchill installed and I used 1521,443,80,8010 as the port number.
Some of the used <external IP: external ports> displayed a "It Works!"
then I tried to connect with <external IP: external port> / Windchill This indicates ERR_CONNECTION_TIMED_OUT.
I have add the IP and DNS of the PC that installed Windchill in the hosts file of the PC trying to access Windchill.
In addition, after port forwarding, I added the internal port I set as an inbound rule in the advanced settings of the firewall.
How can I access Windchill on a PC that does not use the same router?
Any suggestions to me?
