Sep 26, 2014 8:58 AM UTC
Access in workflow
Hi!
How to extend user's permissions to the target objects in the workflow? For example, in the current product context user have no permission for modifying documents. But in the change activity workflow user on role assignee should modify some documents.
Oct 6, 2014 1:14 PM UTC
I solved it. In the lifecycle template you should mark it as the Advanced. Then
1. Select the lifecycle state you want to extend
2. On the Roles tab add the role you need to give permissions
3. On the Access Control tab select this role and add all permissions you need
4. On the Workflow tab in the Phase Process select the WF you need
4. Save template and reassign the lifecycle template for all documents you need to move by WF
Oct 3, 2014 12:51 PM UTC
I have set specific permissions to the assignee role. When assigne activity is going on, the user with the assignee role (that defined in the workflow team) doesn't have specific permissions. But when I add user on the assignee role in the context team - he have that permissions.
Which settings I should make?
Thanks!
AntonBagryanov1-VisitorAuthorAnswer
Oct 4, 2014 7:20 AM UTC
Hi Anton,
You may set the permission from the policy administration to specific Role.You must know which life cycle state your object would have when the task goes assigned user/role, based on this you can provide modify access to that role.
Nov 15, 2022 3:54 PM UTC
Anton, In your example, are the Documents going through the workflow?  I need something similar but I need to modify the permissions on the resulting objects of a CN task.
