Jul 9, 2015 8:29 AM UTC
Accessing WS and CS to find the part
I need to search the part from the creo using Web.link . once i start the search i will look into the ws if it is not there it needs to goto windchill WS or CS and then check out and download into the creo location.
function ToGetWSName()
  var mGlob = pfcCreate("MpfcCOMGlobal");
  var oSession = mGlob.GetProESession();
  var CurServer = oSession.GetActiveServer() ;
  var ActServer = CurServer.Alias ;
  var ActWorkspace = CurServer.ActiveWorkspace ;
  ws_path = "wtws://"+ActServer+"/"+ActWorkspace+"/" ;
  return ws_path ;
this is the code i used to get the WS . can any one help me to search from CS and checkout and dowmload into Creo??
20-Turquoise
Jul 9, 2015 2:02 PM UTC
I have never actually checked out a model with weblink however the pfcServer.CheckOutObjects() and pfcCheckoutOptions deal with checking out objects. Since you are linked to Windchill you don't need to "search" for a model you can simply just "open it" and if it is not already in the workspace then it will be added to your workspace and then opened.
To open a model in weblink would go something like this.
Assume you have xyz.prt (that may or may not be in the workspace) that you want to open and display in a window.
var modelTypeClass = pfcCreate("pfcModelType");
var modelDescriptor = pfcCreate("pfcModelDescriptor").Create(modelTypeClass.MDL_PART, "xyz", null);//creating the model descriptor
var model = session.RetrieveModel(modelDescriptor);//retrieving the model into session.
//At this point you can work with the model in WebLink you do not need to open in Window
var session = pfcGetProESession();
var window= session.CreateModelWindow(model);//create a window
model.Display();//display the window
window.Activate();//activate the window
