3-Newcomer
Jul 2, 2024 2:38 PM UTC
Add a new master attribute to Edit Common attribute layout or wizard
How can I add a new master attribute to Edit Common attribute layout or wizard? For WC 12.0
joe_morton
Jul 3, 2024 6:43 PM UTC
I would think that you could add a new attribute on the Part Master in the Type and Attribute Management, but I've never tried it.
This article says it is not possible: https://www.ptc.com/en/support/article/CS147766?source=search
3-Newcomer
Jul 4, 2024 5:10 AM UTC
@joe_morton  thank you for the input, but Adding in the JSP is the only way as of now I have found to perform this operation.
