Feb 25, 2019 5:05 PM UTC
Add a ‘Read’ value to the input/output files options in the FRACAS Admin Module
Please refer the attachment for proper understanding. It has pictures for better description.
Current access options are:
No access – Prevents the user from selecting the item or using it.
Modify – Allows a user to access an item, change it and then save it.
Create – Allows a user to create new files.
Delete – Allows a user to delete items in the system.
'Read' option should allow a user to access a property and change it but then not save the changes they have made. This would be exceptionally useful for ourselves with giving users a default table format view that they can modify but then are unable to save when they close the application, thus not affecting other users.
The current set up seems bizarre to go from no access at all, to being able to modify and save changes. There needs to be an intermediate level.
Thank you
Mohammed
Feb 26, 2019 8:52 AM UTC
This functionality would be very helpful in our organisation and system set up.
Currently we are stuck with allowing everyone to change the incidents table view for everyone else or not allowing them to change the incidents table view at all.
Due to the wide ranging customer base, users need the ability to arrange data in the way they need but then not affect other users when they close the system which is what  'Modify' currently gives them.
Great idea!
Feb 26, 2019 11:49 AM UTC
This is a great idea that would benefit the way we set up users in our system.  Due to the large customer base, the users need the ability to rearrange data in different ways without it changing the way another user has set up their information.
