Jul 12, 2015 3:01 AM UTC
Add custom step only for subtype of wtpart in createpart.jsp
I have a sub type of wtpart called Regulatory Request.
I have added line item table at step 3 in createpart.jsp.
Line item step is showing for all wtpart subtype. I would like to display the step 3 only for regulatory request.
Sithik
Jul 13, 2015 2:05 PM UTC
Hi Sithik,
You can follow the below steps
1. Make the wizard step as hidden by default in the custom actions xml file.
e.g.
<action name="test"  preloadWizardPage="false" required="true" hidden="true" >
<component name="test.test" windowType="wizard_step"/>
</action>
2. In the main JSP file using JavaScript function retrieve the type of the object and use below function to display the step at runtime.
  • if (yourtype){
    insertStep(customStepId);
Same mechanism is used on Wtpart details page when you select the checkbox to create a cad document.
Bhushan
Hi Sithik,
e.g.
</action>
  • if (yourtype){
Bhushan
ShirishMorkhade
Jul 13, 2015 10:30 PM UTC
Thanks for pointing this out Bhushan.
I am able to make it work using below steps:
Below is an example of custom JavaScript function:
function customToggleCustomWizardStep(wizardStep) {
    var ele = element = document.getElementById('!~objectHandle~partHandle~!createType');
    var type = ele.options[ele.selectedIndex].value;
    var desiredPart = "wt.part.WTPart";
    if(type.toLowerCase() === desiredPart.toLowerCase()) {
            // alert(" Inserting Wizard !!! ");
            insertStep(wizardStep);
    } else {
            // alert(" Removing Wizard !!! ");
            removeStep(wizardStep);
And, below is an example of JavaScript function call:
<script language="JavaScript">
    PTC.driverAttributes.on("afterRefresh",function() {
        customToggleCustomWizardStep('CustomActions.customWizardStep');
</script>
Where: CustomActions.customWizardStep is wizard handle.
Shirish
Jul 14, 2015 1:47 PM UTC
Shirishkumar Morkhade thanks for putting it together.
PTC.driverAttributes.on("afterRefresh",function()  call is actually necessary as we want to hide the step based on the type selected. This is a good addition.
Sithik Rahamedhulla,
Example code from Shirish should be the exact resolution for your query.
Bhushan
Jul 23, 2015 1:39 PM UTC
Hi Bhushan,Shirish,
Thank you for your reply. I am able to add custom step based on the type of WTPart.
Sithik
